Big rip in vinyl liner, not sure what to do for winter.
Danny56
11
Illinois
I have a 10k galloon above ground pool with a vinyl liner. When I was vacuuming it today the liner ripped between the ground and the pool wall, and a lot of water came gushing out. So far I out a towel over the about 8 inch rip in the liner. I wanted to winterize it tomorrow, but now that it's leaking pretty badly, I don't want to bother putting on the cover. Is it okay if I leave my pool uncovered for the winter? The liner is shot and I don't care what happens to it, I am just worried about the pool walls and the structure of the pool itself. It does snow here and it can get down to 0 degrees. The liner is 8 years old so I want a new one, I am just wondering if I can hold off until the spring? If not, any ideas on what else I can do??
Mdragger88
1,586
Hernando, Ms
If you could patch it to prevent leaking/ sand washout over the winter that would be the way to go. Otherwise it will drain itself in places you don’t want it to go. Can you just drain & install a new liner now? Not sure if you’re in northern Illinois or southern Illinois. Obviously temps are a concern.
