I just had the same issue as those in this post from years ago. I’m hoping I can workout my issue and share whatever I do to fix it.
First, I know the pump is getting power because the timer lights were working. The test button does nothing. And neither does the reset. The pump isn’t running. It’s possible the pump is broken. Though, if the Gfci fails, the pump will appear to not work since a failing GFCI will interrupt the power source. The I stands for Interrupter. This leads me to believe that either the GFCI is successfully failing or the pump is trash. Given that others have successfully replaced the GFCI, it seems smart to replace the cheaper and more likely culprit first.
I went out to see if the plug thingy was easy to remove. Lucky for me, there were screws on the back. I took the 4 exterior screws out and the backplate came loose. Then, I took out the 2 screws that were securing the cable. Once that was off, I loosened the 3 brass screws holding the hot, neutral, and ground wires. After that, everything came loose. Here’s where I’m at right now.
Next step is to lay out the facts and what I know. this grounded (3 prong) plug is a GFCI and a timer. So, it needs to be replaced with a GFCI and a timer. There are plenty of ways this could happen. Maybe there’s a combined apparatus that will quickly solve the issue. Or maybe I get 2 separate things. Or I replace my outlet with a GFCI and just get a timer.
I do have a space restriction since I have one of the little white boxes around the outlet.
According to How to Replace a Power Cord Plug, I can replace the plug with one of these for <$5. Once I do that, I’ll still need a GFCI and a timer. I like the idea of having them separated. That way when something fails I can more easily diagnose what the problem is.
Regardless of what I just said, I have decided on not separating everything. I’m going to try this timer and this inline GFCI replacement plug. This way happened to be cheaper and will be slightly quicker. We shall find out tomorrow if they fix my issue.
I think @theedaddyduck’s Timer mod will be helpful
To be continued.
To be continued.
