Hi All,
Reaching out to see if anyone can offer some advice with filter pressure.
I have a Bestway 58486 Sand Filter which is running fine but always runs at higher PSI than the manual states. Manual says it should run less than 8 PSI in normal operation, and clean at 9 PSI. However, ours always runs at a starting point of 9-10 PSI - regardless of long backwashes/rinses, it never goes below. Conversely, when we are in CIRCULATE mode (and bypass the filter media) then the pressure is indeed very low and flows fast. So something is causing higher pressure when traversing through the filter media.
I am not sure how much of a problem this extra pressure is, and what you think the problem could be? Could the sand itself be an issue (even though it's No.20 Silica) or do you think one of the laterals is blocked, broken etc? I certainly cannot see any others issues throughout the system.
Really looking forward to hearing people's views. Being new to Sand Filters, it leaves you with an uneasy feeling!
Brad
Brad
