Ok guys, need to pick your brain to protect my crazy "running-in-winter-dome-in-Michigan" scenario.
I have a little 60 amp sub panel in the pool house with a 1 hp, single-speed hayward superpump. There is also a square D box down line from panel. My raypak also feeds from this. All equipment is in pool house and. Can override thermostat to run gas stove type heater to keep same above freezing.
My electrician friend is coming out Dec 3 to wire in a PE653 Intermatic, but isn't avail til then. At that time, I want him to make whatever adjustments needed so I can run a small backup generator in case of winter power outage. But I want to get parts etc. in advance, and have a plan. Eg. Interlock or some such. Or Maybe a transfer switch?
And yes, I want to make sure I don't kill a linesman by back feeding Worked for the hydo co. summers in college and know what this is Just don't know much about generators and my general electrical knowledge is scant or forgotten from disuse and old age...
I am keeping my water temp at 94 degrees, so I would have a bit of a window to work with before I'd be in trouble, but if the power goes out, the dome goes down, and then I can't get in to plug the lines so blowing out the lines would be problematic to say the least. (Of course, once I actually get a little generator, if it could handle 7 amps from blower and cyclone, I could resort to this...but if possible, rather just keep the water moving.)
A whole house back up gen isn't in the picture at the moment because I've blown the budget this year with the lifetime roof, new liner, new heater, dome and imminent observatory platform. Our estimate had been in the neighborhood of 20k -- we have 3 panels running 3 separate spaces (house, studio and pool house.)
So I'm just looking for reccs on a good hand-crank generator, powerful enough for pump and maybe dome blower, and the specifics of the best way to do this, plus any caveats.
This is not DIY so do not worry about giving me advice whereby I will harm myself or others just want to get my head around it and purchase the generator as winter is coming, as they say
