Hello,
My pool guy just installed a new Jandy 2.7 HP variable speed pump, along with a JEP-R controller. When we discussed it I told him that it absolutely needed to be integrated into my older Aqualink RS6 which is not able to talk to a variable speed pump, and that I wanted him to just use the Remote Contact function because I only need two speeds, low for filtration, high for Spa. Unfortunately, he didn't do that. Instead he installed a JEP-R and programmed the timing into there and had no answer as to how they were to be integrated.
It feels like I'm on my own here to figure this out. The remote contact function looks like it just needs a complete circuit to activate the pump on the desired speed (1 to 4). I was thinking I'd just use a relay in the power center to close a contactor. Before I start buying random parts has anyone done it this way? I really don't want to spend $1,200 to upgrade my Aqualink.
Thanks!
Thanks!
