Our AquaSport 52 18' Round pool is now constructed and we are ready to install the foam cove then lay and compact the sand base. I purchased the right amount of Gladon foam cove from Amazon, as recommended by the place where we purchased the pool.
Two questions:
1) I was planning on installing the cove then laying the sand base on top of that. It should work because the cove is 3.5" high and we are doing a 2" sand base. Is this the right way or do you lay the sand base first, _then_ put the foam cove? That seems problematic because the sand will settle but the foam is stuck to the side of the pool.
2) Our AquaSport is not round but is a Dodecagon (12-sided) with 150 degree angles in between each side. Is there some trick to make this work or do you treat it like finish carpentry and cut two adjoining pieces each at 15 degrees?
Two questions:
