- Jul 21, 2013
- 65,115
- Plaster
- Pentair Intellichlor IC-60
The nice thing about a forum is other people tend to follow along or stumble upon at a later date, it seems worth noting this system does work for both types of heaters.
Well I am glad you finally said that.
Glad to get you back on topic of the OP.I also find it odd just above you are quoting a different post asking about tracking gas heater run times in response to the op questioning heat pump usage, which you most definitely can meter.
And you elaborated that "this is definitely not something that is DIY if your not familiar with volts and amps".
Now if the OP understands what you shared I am sure he will follow up on this thread.
