So - pool is filled finally (YAY) and need to start off by adding CYA (I am DONE with those stupid tri-chlor tablets).
I purchased a bag of Clorox 100% CYA from Wal-Mart, and per the TFP app, I need to add 41oz, or 2lbs, 9oz, to get to a CYA of 45ppm on my 6900g pool. I was reading to NOT broadcast it out as it will not dissolve well, and could also stain the liner. I have read to put it in an old sock and let it hang over the side, use panty hose, or to put it in your skimmer (which I do not have).
Given I have the Intex sand filter, is it okay to pour it in to the waste basket catch and not to run it on "filter", but on "recirculate" instead for 24 hours? I know it takes 2-7 days for the stuff to fully show on readings, but, I do not want my chlorine to all go to waste until then.
Thank you.
Thank you.
