Best time to start slamming
mnhim001
53
San Dimas, CA
Hi Guys,
I am going to start slamming, but just wondering the best time of day to do this?
CYA is between 30-40
FC = 1
CC = .5
PH = 7.8, just added some muriatic acid to lower it to 7.2
Whenever you get to it. Time of day does not make a difference. Get it going.
For CYA 40 your SLAM FC is 16.
Reactions: Mdragger88
Whatever CC you have is the way it is for your pool now. every pool is different.
Do you meet the 3 exit criteria for the SLAM process?
  • CC is 0.5 or lower
  • AND you pass an OCLT (i.e. overnight FC loss test shows a loss of 1.0 ppm or less)
  • AND pool water is crystal clear with no visible sign of algae (dead or alive) on floor and walls
When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
I see, but during the whole slamming process (been only 24 hours) my CC has always been 0.5.
If your CC is over 0.5 you have an issue and a SLAM is recommended to resolve.
If your CC is 0.5 or less, you may or may not have an issue. CC is different in every pool, in every situation. CCs are not automatically created / building up when algae is being killed. Sometimes they dissipate to the sun and such as soon as they're made. High CCs are typically more a byproduct of ammonia or ammonia products interacting with FC - elevated CC typically means biological ammonia waste in the pool (someone peed in it) or other ammonia sources. The link Allen posted upthread has an explanation of why oxidizing algae doesn't usually make CCs.
Thanks for explaining it more clearly.
I Just finished slamming my pool and everything looks great!! Thank you all for the help.
My next question is...do I want for the FC to get back to normal levels or can I start balancing the TA? My TA is at 220ppm right now.
Once the FC is at or below 10 ppm, then the pH test is valid. At that time, adjust the pH into the 7's. Test pH every other day and lower the pH to 7.2 or so.
