Best Test Kit
Status
Not open for further replies.
o I need the Ph meter that is optional, its checked for 17.00 more?
Really no, it is low quality.
If you really want a pH meter get something better.
Try the pH test that comes with the kit before you get a pH meter.
PH meters for me are a waste of time and effort. When I do the pH test its rinse once and again with the pool water then fill to the line, five drops then cap it, flip several times to mix and use the instruction card as a backlight to the oto block and READ THE RESULTS. Simple and easy to decipher the matching color. Even if you're off by one point (.) it won't make a major difference.
Reactions: IceShadow
Status
