Drain bladder/Drain King, air compressor, snake, etc?
Suspect clog in skimmer line (single skimmer/main drain set up) rather than air leak. Had 17 frogs (<1”) in skimmer after a rain. Pump surging next day. Discovered several frogs in pump basket. Turned pump off and on several times and would get 1 new frog each time. Went from surging to almost no flow from skimmer line after that. Normal flow if I isolate the main drain.
Best method to try to unclog?
Thanks
Thanks
