It’s a cost cutting & performance cutting filler used in place of expensive plastizers.
No, none at all. They have great videos and a lot of information, but they seem to do a pretty high volume and from those on this forum, it can be challenging to get parts at times if something gets messed up in an order. I am not able to speak to the quality of their liners, you will need to call and research them. I am a DIY'er, literally do anything myself I can. For my pool, I had a pool guy order a quality liner from GLI via a local distributor, and I had the pool guy pour my cantilever coping. Those two things are the first thing you notice in a pool, so I got the best I could.
It’s hard to get them to open up about raw materials etc.. it takes work to nail it down.
some are revealed in msds papers & independent
White papers..
the white papers have a very heavy price tag, not realistic to expect an enthusiast to purchase.
The dealers who really know their stuff are generally excited to discuss & unfortunately many have no idea.
Generally when the same pattern is available through several companies but with a different pattern title - avoid it.
Poolguy!!, that is an extremely helpful comment..."Generally when the same pattern is available through several companies but with a different pattern title - avoid it." I have seen a tile pattern at at least 3 manufactures. I would assume that this is because there is a 4th party involved and this is a mass produced cheap liner? So say there is ACME Liner Manufacture, the dealer, and me, thats the 3 parties. The 4th would be some other foreign manufacture that ACME is buying a few patterns from?
MSDS Sheet, great advice, I'll ask for that.
Focus on the repetitive pattern not the manufacturer. Manufacturers buy and weld the sheet material, some have good & junk material in the same brochure. & some only buy good stuff when inexpensive material is not available.
Nobody is required to furnish you with documents, liners are not a regulated product.
& the docs are from raw good processors - way up the food chain before the product becomes a pool liner.
Look at the brands named earlier- there is no junk in those lines, if you need to buy through a dealer, so be it..
& your welcome.
Btw - where do you live?
WOW, to your point!!! Each of these manufactures (including Merlin, GLI and Vynall) had the same one we have been looking at…
Loop-loc even had an icon to say which were “by Loop-Loc”. Loop-Loc actually did not carry the one I am talking about
Manufacture List: Pool Liner Manufacturers
Each of these below is the same liner
http://www.dovervinyl.com/images/linerstemplates/margate.jpg
http://glipoolproducts.com/core/media/media.nl?id=790597&c=760191&h=bf3e8cbfa874d7017dfc
http://www.kaydenliners.com/wp-content/uploads/2014/12/Rustic.jpg
https://lathampool.com/wp-content/uploads/2018/01/latham-pool-liner-mountain-top-blue-mosaic.jpg
Siesta Key Tile
http://www.pegasus-products.com/wp-content/gallery/pegasus-in-ground-liners/Mountain-Top-20_27.jpg
http://www.precisionvinylcorp.com/images/mountaintop.jpg
OOOOOOOOH, ok ignorance. The manufactures are buying the preprinted material and welding it together. Got it. Ok, so why would that lead us to believe a common pattern is made of cheap material?
This is the perfect time to say ‘ dime a dozen ‘ ..
I believe it because I have seen 3rd party analysis & accelerated fading and short service spans in the field and i am tuned into industry grapevines.
A dealer can order to your dimensions, as long as the #s get through the CAD & the numbers add up over all dimensions.
