I will have a 8ft x 8ft equipment pad area that will be located to the side of the pool house. The two options I want to look at are locating the equipment along the side of the pool house from front to back. The second option is to locate the equipment across the back of the equipment pad.
Advantages across the back:
I can't tell you exactly what will be out there but there will be a 2.7hp variable speed pump, a controller with SWG, a heatpump, a blower for the spa. All Hayward as far as I know. Sketch below. PS: shows 6x8 but it will be 8x8
Further away from everything
Easier to hide
More room to walk around in front of
Advantages along the side:All devices may have shorter run to the electrical box
Can't think of any other
Originally, the pad was 4 x 8 with the long run beside the pool house and the only option was along the side but now that the pad is the same both ways, it could be changed. The builder may have his own plan and reasons why one direction would be better than another but does anyone here have any input as to why one way would be better than the other?I can't tell you exactly what will be out there but there will be a 2.7hp variable speed pump, a controller with SWG, a heatpump, a blower for the spa. All Hayward as far as I know. Sketch below. PS: shows 6x8 but it will be 8x8
