I know that this topic has been discussed multiple times. I understand the different types/methods of chlorinating my pool. However, I am really struggling with the best method to use to chlorinate my pool.
I have a 27' x 52" round above ground pool with a cartridge filter. I have been using bleach. I use liquid 10.5% chlorine when i can find it. I live a an area where, for whatever reason, I often cannot find liquid chlorine. My water chemistry is good. Everything is at ideal levels. The water looks great.
While I have been doing well with bleach and/or liquid chlorine, I find that I have to use so much of it. I hate the thought of throwing away so many 1 gallon jugs. I am in a very rural area. We don't have a recycling program and I am unable to find a pool place here that will sell liquid chlorine in bulk or refill containers. Additionally, liquid chlorine just doesn't seem to stay in the water as long as other methods and requires me to add it every couple of days.
I understand that Trichlor tablets contain CYA and will raise those levels in the pool. My current CYA level is 40. But man, are they convenient until your CYA gets too high. If it weren't for that, I would use this method. I have an inline chlorinator that will hold 10 3" tablets at a time. I used it for a little while last summer while monitoring my CYA. Then stopped and switched back to liquid when it got above 60.
I keep going back and forth about getting a SWG. With my pool being above ground with so many metal components, I am worried about corrosion from the salt. I have heard lots of arguments on both sides as to whether or not salt water takes a toll on metal above ground pools. So I have been very undecided on whether or not to go this route.
Given my situation, what are your recommendations for chlorinating my pool?
Thanks!
FC: 6
CC: 0
CYA: 40
pH: 7.6
TA: 100
CA: don't measure b/c irrelevant for vinyl pool
Thanks!
FC: 6
CC: 0
CYA: 40
pH: 7.6
TA: 100
