Wow, You had a heck of a FC drop in a day. I'm sure that little to no CYA is the culprit there. (So go ahead and add the stabilizer as planned).
All your other numbers look pretty good over all.
I think once you get your CYA up to at least 40ppm, so your chlorine holds, then adjust your FC up to the Slam/Shock level for that CYA, and maintain it there until all 3 criteria for OCLT is achieved you should be in really good shape level wise, and any algae should be dead in there . I hope this helps. Have a nice night.
