So my cya even after a winter of only using powedered shock was still at over 100ppm. I use the taylor 2006-c kit. Everything else is fine other than the random odd battle with mustard algae. It seems my chlorinator is also putting weay too much water through it and never completely shuts off when closed. So now is the time to get off the tablets.
I am currently refilling my pool from a 50% drain. So my questions are these:
1. With liquid chlorine from the pool store hitting 38.99 for 4 gallons, what is the best exonomical way to chlorinate the pool? With a 15,000 gallon pool how long will a gallon of liquid chlorine last me?
2. So from the pool school it seems I will be testing daily for chlorine and ph, and adding chlorine daily? This is just the required amount to dial in to the amount of FC I need correct, not shocking? What is SLAM I keep seeing referenced (I will search the forums in a minute).
3. Would using up my remaining tablets be ok for adding some stabilizer if it gets low?
Thanks in advance.
Thanks in advance.
