Butterfly said:Just in case you need it, here's a link on deep cleaning the filter:
my-sand-is-channeled-how-to-fix-it-t7626.html
Stihl manufactures several solutions to your problem!!Attached is my view from 5 feet out in the pool.
You did all that! I'm tired!Dieter said:Alright, did the hose in the sand deal, used a long handle tool to make sure nothing was gunking up the impeller, brushed the whole pool and left the pool at 20.5 FC, 0 CC, 7.3 pH. Pool brush about 5% visible at max depth of 9 feet. Filter shows 19 psi. Pool about 84 degrees. Hoping for any improvement by tomorrow.
duraleigh said:Stihl manufactures several solutions to your problem!!Attached is my view from 5 feet out in the pool.
Bama Rambler said:How many days have you passed the OCLT except for the clear part?
RobbieH said:So I must have missed that the T100 was a new addition. Do you know if it was THOROUGHLY backflused after adding the sand? We did a 5 minute backflush on mine before ever starting it up, and I think that's proper procedure.
JohnT said:I kind of think you might have reached the point that a double dose of clarifier is called for. We don't normally recommend it because it's often just used to mask a symptom rather than fix the cause, but in certain cases, for example when there is no underlying chemical cause for the problem, it can be a good step.
I've been in a similar situation to yours a couple of times and clarifier made about an 80% improvement in 24 hours with crystal clear just a few days out. May be worth it.
Bama Rambler said:Thanks, I'm keeping a log of clarifiers and whether they work or not.
