Hi, Does anybody have recommendations for the best stand-alone battery pool vacuum for my pool? I have a 12 foot above ground pool (see below). Have a lot of sand as well as small and large debris on the bottom. I can't use a manual vacuum because I've had to bypass my skimmer. (It was a proprietary brand from a pool store here on Long Island that sells its own brands only so I was reluctant to try to replace it mid-summer. I have rigged my intake hose similarly to the way hoses used to be rigged years ago before skimmer weirs were cut into the liner/pool - my hose goes over the rim & directly into my pool. Its weighed down with sand in plastic bottles. Works fine for filtering water but I can't attach a vacuum to the hose.)
Pool Blaster? If so, which model? I have a Jandy venturi leaf vacuum but I think the sand will pass right through the bag and/or knock the bag off.
Thank you, Swimcat
Thank you, Swimcat
