I have 'the pool cleaner' suction vacuum Baracuda, in my in ground pool and the hose plugs right in to the side of my pool. I was wondering when we go swimming is it ok to just unplug the vacuum hose and remove it from the pool while the pump is still running without having to turn off the pump? There's a cap that drops down and covers the hole that the vacuum hose plugs into, I just want to pull the vacuum out while were swimming cause its in the way!Thank you
