Hi
Finally i got my Taylor 2006-C test kit and had first set of data . Leslie result for CYA & CH are 85 & 220
here is Taylor results ( 13000 G)
FC=9.2
CC=0.2
PH=7.4
TA=80
CH=500 ( city average is 270)
CYA=120-130
After reading all discussions and advises ;
needs to Reduce CYA to 30-40 ( via dilution and i think this also will be improved CH ??)
then needs to use liquid bleach/chlorine as long as possible...
Question is here, if pool is in balance of FC/CYA no need to shock the pool? what if happen needs ? and this should be via Cal-Hypo?
If FC/CYA is in balance, there is no chance get algae in the pool ? and no need to use any algae chemical ?
Also as most of you advised, no need to care of phosphate and no need Natural Chemistry products...these are supplementary and with or without pool will be in good shape as long as FC/CYA in balance.
Is this that much easy ?
By the way, once again thanks for this group/forums...
FC=9.2
CC=0.2
PH=7.4
TA=80
CYA=120-130
