Hello,
Looking for some help.
PB just completed work on the plaster after a full drain.
Now I'm refilling with city water and will be closing the pool for the season.
Can I close as a chlorine pool and add salt when reopening next season?
Also if I can close as a chlorine pool I should just follow the TFP levels recommendations here.
In doing so I will turn on my swg and run pump/filter till chemicals are in balance for a chlorine pool.
My pet peeve is I have to fill all the way and then drain the pool (under skimmers) to close right after. Any ideas for a work around to save on water with compromising levels?
Thank you for any advice.
