Hi all,
I am having the pool closed Monday 11/1. 30k gallons, pebble tech, SWG. I am trying to optimize the chemistry before closing in hopes of keeping my pebble tech safe through a long, cold New England winter. The pool company will add algaecide and 4# of dichlor quick shock at the close. Probably nothing else.
Current Test results (with Taylor Kit):
pH 7.6 (I will correct this down a bit in a couple days. I have a waterfall and constant pH rise. Target should be 7.4??)
Chlorine Free 4. Combined 0
Alkalinity 75
CH 200.
Water temp: 54 degrees.
We have just had a TON of rain here. Once it stops I plan to raise the Alkalinity a bit (target 80-100??). Do I need to raise Calcium Hardness too? Any issue dissolving Calcium Up in 54 degree water (I have Pro Team Calcium up - it is flakes not pellets)? Pre-dissolve in a bucket first? I am terrified of staining my finish with chemicals that hit the bottom. Can I leave the CH alone? Or should it be higher pre-close for a pebble tech pool?
Thanks!
Alkalinity 75
CH 200.
Thanks!
