As soon as the FC level is below 10, hopefully right now, adjust the PH to between 7.2 and 7.4. Then resume bringing the FC level back up to 15 as frequently as practical. Chlorine is much more effective when PH is at the low end of the normal range.
Having zero CYA when starting a Baquacil conversion is normal. Baquacil doesn't require CYA. You might as well start adding some CYA, aim for a CYA level of between 30 and 50. Remember that it is far simpler to raise CYA than to lower it, so aim a bit low and touch it up later, so you don't overshoot. Also, CYA can take up to a week to disolve, so add some and then wait a week before retesting.
For testing very high CH levels you can use a variation of the test. Use a 10 mL sample, 10 drops of R-0010, 3 drops of R-0011L, and each drop of R-0012 then counts as 25 ppm. This goes more quickly if your hardness is high, plus it saves on reagents (all at the cost of reduced percision which doesn't matter at high levels).
You continue adding bleach as frequently as practical (but not more than once an hour) to bring the FC level back up to 15 until the FC level holds at 15 over night and CC reads at 0.5 or lower.
Your alkalinity is a bit high, but I think you can wait on that until you are done with the conversion. It is much simpler to deal with one thing at a time and the alkalinity will come down noticably, though probably quite not enough, when you lower the PH.
