Howdy all,
I have a DE filter assembly with a filter currently running in it. It does a good job cleaning the pool; however, after every morning startup it shoots a bunch of sediment into the pool. As far as I know, this is because I need to backwash the filter. I know that under normal circumstances there is a valve on the Outlet side of the Filter Housing you turn to initiate the backwash, however, if you look at my screenshots you'll see that the valve in question has been screwed in place and locked up.
Given the attached pictures, does anyone know how I would go about backwashing this particular filter assembly?
Thanks.
Thanks.
