I backwashed and recharged it about 2 months ago, the pressure is at about 20, and I was told by the original owner that it would normally sit around 15, and if it goes up, just bump it and it should loosen up and go down.
Lately, I am seeing more air bubble in the pump filter window, turning off, bumping causes the bubble to reduce but it comes back occasionally. Could it be because filter is getting clogged? When I backwashed, I don't believe I got all the DE out, and it's a very old filter I don't want to try to open it up unless I absolutely have to. I was thinking maybe I can ride this pool season, and clean it during closing? Pool is clear, occasionally will start growing some green spots, I just recharge the chlorinator with 2 x 3" tabs and turn the chlorinator to 5 or 6 (7-8 is highest) on my CL200 Chlorine Feeder. This seems to help but I still have to brush daily, vacuum every 2-3 days using Polaris.
I do feel like I may need to get a new pump and equipment next year.
PS: I don't have multi-valve.
