Backwashing floods pump room
emonMPC
11
Phoenix, AZ
When the pool person back washes, it floods the pump room. It used to have a short piece of backwash hose to the drain which is pretty much right under the outlet (about 6-8 inches above). A few years back, they actually cut a hole in the brick wall to allow it to run out of pump room but its pretty messy. If my memory is correct (may not be) it wasn't always this way (lived across from pump room for 35+ years). Pool person said backwash hose won't help. Does this sound normal? Also can the amount of water released during back wash be controlled or is it just on and off?
Got a picture? Can’t really control backwash pressure unless you can lower the pressure of the pump. But you can certainly run a hose from the backwash valve to a drain or even into the yard to water the grass
Reactions: emonMPC
That little drain hole in the floor is inadequate for the volume of water a pool pump can discharge.
You need some proper plumbing and drains.
That drain is probably clogged up (and it’s too small to handle the discharge). It’s not the pool service guy’s job … whoever owns the property and the pool needs to hire a plumber to fix it.
Reactions: emonMPC
A gallon of water may go down the drain without much issue. But the drain is inadequate to handle 60 gpm or more during a backwash. And it's unlikely the drain can even handle the flow from the downspout as well.
