If it is not running on the pump performance curve, like with the wrong impeller, then it should be more obvious due to extra low power draw?
Yes, even though the power curve may not be exact, we might still be able to determine significant deltas that might indicate a particular issue.
Also, I made a slight adjustment based upon the label wattage to make the pump motor a little more efficient and I put the possible plumbing curves as an overlay.
Operating point A' assumes:
- Pump pressure and suction gauge measurements are correct
- Flow meter measurement is incorrect
- Pump is operating on the DMJ head curve
Operating point B' assumes:
- Flow meter measurement is correct
- Pump is NOT operating on the DMJ head curve
Operating point C' assumes:
- Pump pressure and suction gauge measurements are incorrect
- Flow meter measurements are correct
