Little history on my situation - Purchased a home where the pool sat without a cover and unused for 3 years. The pool is 15 x 34 ft rectangle and roughly 15,000 gallons. There was a LOT of debris I've been pulling out.
I would run the pump on and off to circulate the water. After initially backwashing, the pressure was 15psi. It would climb to 19-20psi over a day at which point I would backwash for 3 minutes. This has been done 6-7 times over the past week.
Now when I have the valve in the backwash selection, pressure will hold around 26psi with barely any water coming out of the backwash hose.
Valve damaged? Media tank full?
