I have a Zodiac G62 black backup valve that came with my sport 3900. It is about 1 year old and I noticed that my polaris is stuck in the corner all day long, most of the time with the wheel spinning and tail moving and whenever the backup valve kicks in the tail stops and the wheel stops but it never backsup. I pulled the line and the backup valve out of the water and laid it down next to the pool to watch it and there is a small tiny leak from the swivel connector on the line but no leaks from the backup valve. When the backup valve kicks in it shoots water out of the side whole and it does look like its working like it should.
What could be the issue?
When the backup valve kicks in should the polaris unit shoot water out of the back?
Is the force from the backup valve too weak? I do have a booster pump attached and I can tell that the water pressure is good.
Anything else that I should look at?
I tried to take the backup valve apart but it looks like it was fused and I was unable to turn it.
