I've read several threads about cracked steps and most mention the underlying cause is most likely the steps aren't properly supported. I only have surface cracking but the top step makes a crackling sound and has some give, which makes me think it could turn into a bigger problem in the near future. There are some older posts about cutting the top step, backfilling with sand, then foam to fill in what the sand couldn't. My husband is a lineman. They use Rainbowtech polyurethane foam to set utility poles. This is different than canned foam as it is mixed, poured, then expands. So wanted some opinions about using just this type of foam and no sand? Possible risks? Anybody perform anything similar?
