Hey all, been a few years since I had a pool and was an active TFP member, but with a new move, I am back in the deep end! But this pool is significantly older than my last.
There are two valves that I need help IDing. I believe they are for main drain and skimmer. If I turn the closest one shut, I get suction at the skimmer. If I open it all the way, the skimmer is off. The other valve appears to be broken, it can open all the way but will never close. I can hear the bearing inside the shutoff freely moving.
At any rate, I am getting terrible pressure, 5 psi at the DE filter. I am sure the pump is the main culprit being 3/4 hp single speed for a 25000 pool. I am already in the process of upgrading the pump to a 2.75 variable speed. Just trying to figure out what this other valve is before I get too deep in things.
Any thoughts?
Any thoughts?
