I have inherited some pool equipment and installed some of my own before understanding that cross-manufacture automation is a bit tricky.
I have researched some of the pentair stuff but it seems quite pricey and honestly doesn't look super sleek(only supports amazon Echo, Android support seems sub par etc). One of their newer products does not support heater control(IntelliConnect)?
What I want to do is be able to control my pool equipment via mobile and ideally Google Assistant.
The ability program set "scenes" such as "Spa mode", "spot cleaning", or "pool mode" would be nice.
The products and actions I am looking to connect and automate would be the following:
I have an existing home automation setup that uses Homeassistant which if I could tie into here via Zwave/some other protocol would be nice.
Are there products that currently target a smorgasbord of products like my setup?
Are there systems which have more customization than others? Being able to leverage an API would be sweet.
* Nice to have not really a priority.
Thanks!
- Getting a remote temperature reading of the pool.
- Pentair Intelliflo 2 VST pump
- Changing speeds, getting alerts if left on etc.
- 1 return and 1 suction valve(Currently have manual 3 port n/l valves 2")
- Do they sell actuators that can be "bolted on" to existing valves?
- Turning on and adjusting my Raypak P-R266A-EN-C Heater
- Being able to set/view the current pool temperature.
- Monitoring of Natural Gas usage*
- Jandy Pool Color LED(toggle power to change light / light sequence)
- Jandy 1.5 240v spa blower
- Booster pump for the pressure cleaner.*
- Auto chemical monitoring/adding*
- Total electricity used*
Thanks!
