I noticed this morning that the cleaning heads are not rotating through the pool, they are fixed on the same 3 or 4 cleaning heads. I also don't see any evidence of water coming out of the ones that are open.
Am hoping for advice on what the likely cause could be? Or any tests I can run to confirm the problem.
Am wondering if it could be linked to the part in the picture - GVA-24, which I think is the Valve Actuator? Is this what powers the cleaning system? Our pool is coming up on 10 years in the heat of Arizona so probably fairly normal that this part could fail after that length of time.
If it is this part, is a like-for-like replacement still the best option or has this part been superseded? Is it something I can switch out myself or do I need a professional?
Any advice would be appreciated.
