So I have had my solar roof heater with the automatic valve installed for about 6 months now. It has the sensor on the roof and if the sun is out the valve opens for hot water and I even wired it so it turns the pump on. Problem with that, that I noticed, is that it could be 60 degrees outside but if the sun is out, the solar valve opens and turns the pump on.....all day....wasting energy and definitely not heating up the pool. So I wondered if there was a way to only have the solar system on when the outside temperature is above a certain temperature. So I got a rainbird smart outlet for only $35. Now the system only turns on when the weather is above 85 deg. And if the sun is out, then the valve opens and turns the pump on. Problem solved!
