B BLPT Active member May 5, 2024 42 Austin, TX Pool Size 9000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 Tuesday at 3:36 PM Add bookmark #1 The autofill was installed 2 months ago. Is the rust on this T joint normal?
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 66,407 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Tuesday at 3:42 PM Add bookmark #2 I would put a coating of rust neutralizer on it... Rust neutralizer: Give new life to rusted metal Rust neutralizer is the solution for renewing metal surfaces. It’s easy to use and less messy than you might imagine. Get the facts here. www.loctiteproducts.com Reactions: BLPT
B BLPT Active member May 5, 2024 42 Austin, TX Pool Size 9000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 Tuesday at 3:43 PM Add bookmark #3 Will it affect the water?
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 66,407 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Tuesday at 3:43 PM Add bookmark #4 BLPT said: Will it affect the water? Click to expand... Nope. It is only on the exterior. Reactions: BLPT
B BLPT Active member May 5, 2024 42 Austin, TX Pool Size 9000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 Tuesday at 3:44 PM Add bookmark #5 ajw22 said: Nope. It is only on the exterior. Click to expand... Thanks!
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 66,407 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Tuesday at 3:52 PM Add bookmark #6 Did a plumber do that? He should have used the same material as the spigot which is not rusting.
B BLPT Active member May 5, 2024 42 Austin, TX Pool Size 9000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 Tuesday at 4:53 PM Add bookmark #7 PB's guy...
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 66,407 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Tuesday at 5:13 PM Add bookmark #8 BLPT said: PB's guy... Click to expand... Call him back and tell him to use an outdoor rated non-rusting fitting. Point out that the pipes on both sides are not rusting. Reactions: dereksanders and BLPT
G Griswald Well-known member Jul 7, 2014 950 Hope Mills, NC Pool Size 16000 Surface Vinyl Chlorine Salt Water Generator SWG Type Hayward Aqua Rite (T-15) Tuesday at 5:16 PM Add bookmark #9 You have a black iron pipe fitting instead of a galvanized pipe fitting. It's an easy fix.
