- May 21, 2015
- 157
- Plaster
- Jandy Aquapure 700
Hi!
So I have a poolmister autofill installed last year (came with my new pool) it worked fine. My pool guy uninstalled when closing the pool last year. When he opened the pool this year it was not working. He said he did nothing and installed the same way it was previously installed. First, there was no water coming out at all. I think reason was he installed it to low. I asked him to installed higher and now the water will not stop flowing. I got tired of telling him what to do so I told him to leave it alone that I would like with it and fix it. I thought issue was just to adjust the float. After an entire day, I cannot get water to stop flowing. I adjust the float to where it should stop, but water still coming out. I manually lift the float and the lift arm to where water shall stop, but water still coming out. I am out of options. could it be the float mechanism is broken (it seems fine to me)? One thing I notice is that there is water coming out the overflow pipe. When I shut down the water line, then the water in over flow pipe stop flowing. I am thinking the float is broken and want to replace it with a Korky 528MP as it seems easier to adjust water level but the water coming out of the overflow pipe is throwing off. Is this normal? I would think no water shall be coming out of the overflow pipe (Though is was meant for water to come in not out) Any help with the issues and comments on the Korky 528MP will be greatly appreciated. Attached are pictures of the autofill.
