We were using the pool yesterday and the pump kicked in which shot out a dose of high concentrated chlorine from the pump not running for 2 hours. The water that sits in the Chlorinator dissolves while pump isn’t running. I wasn’t too worried at the time, but what if a kid was right by the return? Should I unplug pump every time we use pool(which doesn’t sound practical)or only run pump at night? Which thought wasn’t good either. I have timer set up for 2hr off/1hr on which cycles my water 1x/day. Chlorinator was just filled with slow-dissolve 3” tabs, Chlorinator set to 2, 10K Gal pool.
