- Jun 1, 2018
- 14,202
- Vinyl
- Hayward Aqua Rite (T-15)
I don’t think that will work as the skimmer box will still have water in it.You can use a potato (say what???) to shove in the skimmer hole if you don't have a gizmo for it.
I am VERY impressed with your work on the liner/shimmer issue! WELL DONE!!!
Kim
Glad to hear the skimmer isn't leaking. As for the pump, I have one of those too. Sounds like air may be getting it. Did you lube that new O-ring under the lid?Now I am having an issue with the Power Flo Matrix with water only filling the pump basket half way.
it looks like this.Is it a Hayward return fitting?
You shouldn't be having this problem with a 4-day old pump. A cap can be bad internally and not show any external signs of damage. Or this could be a different issue. Did you get the pump locally to where you can exchange it?The capicator did not look to bulge and nothing looked burnt. I read on here about opening the back and using a screwdriver to spin the impaler the pushing the start button - that worked. If I turn it off then I have to spint the impaler again to get it to start.
They’re generally pretty expedient so hopefully u will have a new pump soon.The pump came with the pool kit we ordered from Pool Factory. I will be submitting a warranty claim.
