- Jun 11, 2018
- 388
- Plaster
- Hayward Aqua Rite (T-15)
I checked my FC this afternoon and it was at 1.5ppm and I had CC of 1.5ppm and my pH was 7.5(via my TF-100). It’s the first time I’ve ever seen my CC greater than 0.5ppm.
We had a storm 2-days ago and I had to drain about 4-niches of water to keep it from overflowing(no overflow lines here). I didn’t do a full chemistry check b/c this has happened a few times before and it’s never affected my chemistry. My FC after the storm was 5ppm so I thought I was good. The family swam yesterday but I had to work so I didn’t check my water till today and nearly panicked to see a CC of 1.5ppm. Water is still crystal clear.
I had to go back to work tonight so I didn’t have time to do a full chemistry test. I did have time to drop in 3-gallons of liquid chlorine. I had my wife test the chlorine level when it got dark so I could do an OCLT. FC was at 20ppm and CC was 1.0ppm. I will check it in the morning when I get home.
I’ve been pondering what could’ve gone wrong and then it hit me.......this is the second time I’ve drained 4-5inches of water in a week. We had a storm last week and I drained it. FC levels had been fine since last week then 2-days ago I had to drain another 4-5inches and two days later my FC is 1.5ppm. I assume when I can test everything in the morning I think my CYA may have dropped a lot. At least I hope that’s my problem and not my brand new SWG malfunctioning. What do you guys think?
(I know I needed full tests, I just was in a time crunch and I panicked seeing a CC of 1.5. I know 20ppm isn’t quite SLAM level but I’m hoping it’ll be ok till I get home in the morning).
