I purchased the a number of items from Atlas Scientific
- i3 InterLink
- Lab Grade pH Probe
Also bought Orp and temp probe.
I am using their software Atlas IOT with a raspberry pi. Plan to move to REM once I work things out.
Readings from Temp are good. ORP is consistent (minimal fluctuation). But pH Continues drifting higher.
pH is a problem
pH reads fine when first inserted, But continues rising. May start at 7.4, but after several hours reads 8+. Spent better part of a week discussing with them. At then end they sent a replacement probe. After installing, i get the same behavior. Below is a graph from the software. It is typical of my many trial with the system. Spike are from pump stopping and starting (need to move the enclosure). The datasheet claims it is good to 100 psi. I have searched the internet and their are comments about the probe "leaking Solution".
Is anyone using the Lab grade Probe?
Are you able to get consistent readings with it?
pH is my main reason for installing the system I would really like to figure this out. I have wasted the better part of 2 weeks and would like to get this going.
Are there any probes anyone would recommend? I am hesitant to try another of their probes unless i know I can expect some success.
- i3 InterLink
pH is a problem
