I am not taking on the bet, but I will do the experiment if someone else takes the bet
I'll do my best.
Here is a start at a proposed test method...
I will need to do this in the dead of night so my beautiful wife doesn't see me using her fridge :taped: . First, I plan on removing the milk jugs and stuff to make room in the fridge. Next I will attempt, again under the cover of darkness :batman: , to draw water from pool using a tube the gets down near the bottom of pool between ice and wall to retrieve sample. I will bring the sample indoors and place it in the fridge. I will also place the mixing bottle, view tube and R-0013 into the space I have created in the fridge. I will fill the mixing bottle to the proper level with the pool water. Then I will let all of that stabilize in the fridge for about an hour...the fridge is at ~38F. Next, using insulating gloves, I will dispense the proper amount of R-0013 into the mixing bottle while keeping all components inside the fridge compartment :rambo: . Here is where I have a bit of a challenge as my speedstir's circuit board saw too much water and no longer works correctly
...but I was thinking of putting in a clean (small) stir bar into the mixing bottle and letting is spin for a bit...maybe I can steal a stir plate from work this weekend. My thought was letting it mix for 5 minutes. The next part is also tricky, since I must do this in the dead of night :batman: and in the fridge, I was thinking of finding a flashlight app for my phone that will simulate outdoor light. I think I will place the tube on white paper and have the phone light the sample from one side. Then I will dispense the test solution into the tube until the dot disappears. At that moment I will test the temperature with a quick read thermometer and then note the value. I think I will repeat this 3 times by pouring the sample back into the mixing bottle and always handling everything with insulating gloves. After getting 3 measurements at ~38F (or whatever the quick read thermometer tells me), then I will allow the pool water sample and all the equipment warm to room temperature. We keep our house at ~65F in the winter, so I might need to bump up the temp to 70+...again, must do this at night as to not be observed :batman: . I will repeat the test (3 times) also mixing for 5 minutes and attempting to simulate the same lighting conditions as in the fridge (this will be challenging...maybe I need to go back into the fridge just when I fill the tube to simulate the same lighting conditions, of course still measuring temperature with the quick read thermometer). I am also considering corrupting one of my sons
, and getting two different eyes looking this giving us two sets of numbers. I better look to see how much R-0013 I have...
Thoughts?...
