Hello,
I have had a fairly large stain on the bottom of my pool for several years. I have always suspected that it was iron and have used the vitamin C tablet test a couple of times. It never gets bigger or brushes of, but it is somewhat unsightly and I am ready to get rid of it. I do not believe the source of the metal stain to be the water, but a small piece of rebar that is exposed on the decking. When it rains heavily, I think that this spills water into the pool. (covering that will be on my agenda, too) A few weeks ago, I did a larger scale Vit C tablet test and it made a big difference. The sock, as I rolled it over a few hours left a large clean area. I just don't think sock fulls of Vitmin C filled socks will be efficient. Ha. I looked around at the Ascorbic acid water treatment and sequestration, and I think I would like to try. I was really thinking a one time treatment, not ongoing.
However, after getting through our pollen, leaves and oak tree shoots here in Austin throughout the early spring, I have determined I may have an algae problem. The pollen often looks like algae, making your water green and leaving deposits. the pollen is gone, the filters changed, the debris cleaned, and the pool brushed several times over. Yet, I keep coming up with removable stains on the sides, the seats and a bit in the corner of the stairs and around the jets. Thus I have concluded algae. It is greenish brownish yellowish. Therefore, I am thinking I may need to SLAM. So there are several questions i was hoping you might be able to help me with...
1. Can I do both, separately over the next few weeks?
2. Which to do first?
3.How long should I wait between?
4. Could I have the links to the full process for both treatments?
5. When will the sequestering agent and AA be dissipated? Are those agents safe, My dog does drink small bits from the pool?
6. would the 'Culator' be an effective sequestrant in this situation?
6. do you have any other suggestions?
Currently I am keeping the pool at 5-6ppm Chlorine with a pH goal of 7.5.
water test now = pH 7.8, CL 7, CC 0, CYA <20, TA 120, CH 300+
Thank you in advance!
