Hi all,
As the season is nearing the end, I am trying to think of a way, or a procedure, to keep water from pooling on my winter cover. Last year so much accumulated, that I was left with less than half of the water in the pool that I closed with! The water on top of the cover pushed down on the water in the pool, and it went right out the return hole! I was none the wiser, as the water level appeared to be the same from the outside!
My cover is the solid (tarp-like) ratcheting style. There’s gotta be a way to raise the center enough so that the rain/melting snow just runs off, right?! I can’t be the only person this has happened to! I’m ready to fabricate something out of pvc, because opening this year was a bear (although, what was left of the water IN the pool was crystal clear thanks to you guys & this site!!)
What have some of you, more experienced above ground pool owners, found to be the best remedy?
Thanks!
Thanks!
