I have a Hot Springs Flair (310 gallons, purchased in 2017) that uses the Scepter Salt Cell.
Can someone tell me if the following ranges are good for my setup?
CYA 30-40
FC 2-6 (Will be dependent on CYA)
PH 7.2-7.8
TA 50-90
CH ^100 (am I understanding correctly that, let's say it's at 100 and not foaming that it's fine, but if it's foaming, to raise it?)
Also, does the app have a way to change the "pool" to a spa/hot tub? I've been using it as a pool because I see no way of changing it and I have it set as fiberglass because I don't see a way to change it to acrylic (I believe that's what my hot tub is??)
*I have been using TFP method and app for my pool for a few years now without issue, but new to using this for the hot tub*
CYA 30-40
PH 7.2-7.8
TA 50-90
