Are caps for Paramount PV3 available?
johnjmattingly
Active member
Apr 2, 2021
30
Austin, TX
Howdy folks,
If possible, I'd like to cap a rotating Paramount PV3 pool cleaner head that's installed in the top step of my pool. This head is very close to one of the corners of my pool, approx. 6 inches from the wall. When that head pops up at high pump speed in the direction toward the wall / corner of the pool it creates a bubbling / aeration effect similar to a water feature. This isn't a problem in and of itself, but the aeration that occurs seems to significantly contribute to a continuous rise in my pH. When I run the pump consistently at a low RPM that doesn't cause aeration at that head, my pH is much more consistent. This head doesn't seem to contribute much to cleaning due to its position, and I believe I can save a significant amount on chemicals by capping this head so that it does not aerate the water.
Does anyone know if capping a Paramount PV3 head is possible? If a cap isn't available, is there a non-rotating head that could be installed instead that's pointed into the pool vs. into the corner? I think either solution could significantly reduce my chemical costs this season.
Thanks in advance!
Updating here after calling vendor. There are no caps, only fixed position nozzles for PV3. Paramount is sending me one and the tool used to change out nozzles under warranty for free. CS rep was super helpful. This will hopefully solve my rising pH problem.
Reactions: stevo777
