Hello, recently replaced the main power board and now getting the solid no flow light. This system has the Turbo cell mounted vertically on the jet so no flow switch is present. I tried holding the diagnostic button with no effect. Any ideas?
My aqua trol rj is reading no flow and pump will not turn off while plugged into unit. New board has been put in because it went out last week. Any ideas?
If you can find where the flow switch telephone type socket would be connected to the new circuit board, you can put a jumper on it and that should solve the problem.
