Aquarite thermistor replaced
Jun 19, 2018
47
Nova Scotia
Took a week to receive replacement thermistor via Amazon, my Aquarite is now back functional. I really did not know this was a common thing. I almost took the plunge and buy a new Aquarite panel. Actually it was fairly simple and cost me less than $20 instead of $650. Anyway in the mean time I added too much salt, currently reading 3600 ppm. Should I drain some water and refill ? Can I use SWG now or wait till salt level is below 3200
Just curious, what symptoms lead you to the conclusion that the thermistor needed replacing?
Thanks.
ThanK
Thanks.
sorry for the delay in my replying, Saturn94, first of all my power indicator was not stable sometimes showing on sometimes off with the switch in the "ON" position. Then discovered that it was not generating chlorine even at 100% output selection. the replacement was cheap and relatively easy to do.
Reactions: Saturn94
Thank you. 😀
