Aquarite SWG no display
johnto
8
Ontario
Hey everyone,
My Aqua Right Gold Line SWG display will work for 10-15 seconds then I hear a click and the display will cut out and the panel will not show anything. I have done some research on the forums and have noted that usually a Thermistor will fix this issue. I have ordered a new thermistor but still have a few questions.
1. The current thermistor does not have any cracks in it. When I put a paperclip on the thermistor already on the main board the display board will still not work (I have read that this is a temporary fix so I am not sure why the paper clip method is not working).
2. I have attached a photo of an area where I see burn marks on the board. right next to the black wire it looks like a burned area and when I tug on the wire marked RED the male part of the board that should be soldered on comes loose and completely comes off the main board.
I am just wondering if the issue with my display board is still the thermistor OR is it something else on the main circuit board that is the issue? Thank you
Yeah, the black and red wires on the corner of the board provide 24V to power the board. If the connections are burnt and loose then that is likely your problem.
Hey everyone, ok so I am going to replace the main board. Does anyone know exactly which one I need to order? I just want to make sure that I do not get the wrong one. Please see attached photos for the board (you can see the burned out area on the top right).
