- Jun 22, 2022
- 3
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
Our AquaRite system was working fine on Saturday (reading 3200 ppm). On Monday, salt level read 200 ppm with the check salt and inspect cell lights illuminated. Since, it has been reading 0 ppm with both lights illuminated. No chlorine is being generated. I tried a reset with no luck. The cell itself was inspected and no build-up was visible. Pool store noted salt level at 3900 ppm.
The employee at the pool store was not very familiar with the system and did not have any advice except that the cell (T-5) might need to be replaced. I talked to another expert who suggested it may be the Flow sensor; however, he was unable to send a technician out due to distance. From reading online, it appears it could also be a mother board issue. Any idea why there would be a sudden 0 ppm salt reading? Thoughts/suggestions?
Readings with the pump on are:
0 ppm
85 degrees
31.1 Voltage
0.00 amps
49 P (output)
-0 salinity
Al -7 (aquatrol return jet)
r 1.47 (software)
-Only a slight difference in readings when turning the pump off and back on. Everything else stayed the same.
*Note: current salt water cell is 4-5 years old
0 ppm
85 degrees
31.1 Voltage
0.00 amps
49 P (output)
-0 salinity
r 1.47 (software)
