Hi All,
My Auqarite SWG was working fine for most of this summer. I checked this weekend, and noticed that I was seeing the issue where the power light was not illuminated, and the generate light would be sporadic. At this point chlorine in the pool was very low. After some reading of the forums, the thermistor was broken - I opened the system up and replaced the broken thermistor with the same model (AS32 2R025)
Running the system after the thermistor replacement and now I see check salt / inspect cell showing within a few minutes of cycling from Off->Auto.
Any suggestions on what I should try next?
Thank you!
Current diagnostic readings (after cycling from Off->Auto)
500
70
25.5 (and climbing)
1.02 (and dropping)
63P
-900 (starts about 3200 and quickly drops)
AL-1
r1.58
t-9
I do not believe the pool to actually be low in salt
- tested today via a aquacheck salt test strip is showing at least 2800ppm
Cell Size: T-9
Cell Serial Number: 3E1005-2055603
Cell Age: Unsure, at least 5 years (moved into house)
Runtime: 5 months per year, 10 hours per day, usually 40-50% setting
Thank you!
500
70
25.5 (and climbing)
1.02 (and dropping)
63P
AL-1
r1.58
t-9
Cell Size: T-9
